Neil1975 Posted April 24, 2017 Share Posted April 24, 2017 HelloMy two boys have a Select DCC controller and they frequently snap to wires that fit into the Track A and B sockets as they are not careful enough when they handle it.Normally i just empty out the broken ends from the sockets, expose some new wire, reinsert, job done. This time, though, the Controller seems to be trapped in limbo and is making a tick-tick-tick-tick sound and the display is displaying nonsense.Is there something I can do to break it out of its "spasm" (best way i can think of describing it).Thanks very muchNeil. Link to comment Share on other sites More sharing options...
Howbi Posted April 24, 2017 Share Posted April 24, 2017 Try re-setting the controller......1. Press and hold the STOP button + the two arrow keys. The LCD display will show "C5"2. Press "Select". The display will show "0"3. Press "Select". The Red LED will flash 5 times to confirm the settings. The display will show "03" Link to comment Share on other sites More sharing options...
Rog RJ Posted April 24, 2017 Share Posted April 24, 2017 The "spasm," is probably due to a short circuit caused by those broken wire ends. Check around the connections very carefully for even just 1 strand of wire. Link to comment Share on other sites More sharing options...
96RAF Posted April 25, 2017 Share Posted April 25, 2017 I tend to agree with Rog.If the display is continuously repeating 'garbage' then it is likely to be a short causing the 1Amp power supply to self protect and drop voltage, which causes the Select to reboot, ad infinitum until the short is resolved.Have a good look in the terminals for stray broken strands of wire. Link to comment Share on other sites More sharing options...
Neil1975 Posted April 25, 2017 Author Share Posted April 25, 2017 Thanks all for taking the time to offer suggestions. Gave it another couple of shakes and a blow and that sees to have sorted it. Must have been a cheeky bit of wire hanging around inside.All fixed now and kids have stopped moaning (at least about the railway not working).Thanks again for everyone's help.Neil Link to comment Share on other sites More sharing options...
Rog RJ Posted April 25, 2017 Share Posted April 25, 2017 Thanks for the feedback. It's always good to know that a problem has been solved. Link to comment Share on other sites More sharing options...
