andys steam dayz Posted May 2, 2017 Share Posted May 2, 2017 Hi could anyone tell me what CV needs to be read to find out what number a loco has been allocated on the Hornby Elite thanking you in advance Link to comment Share on other sites More sharing options...
RB51 Posted May 2, 2017 Share Posted May 2, 2017 Hi Andy - CV1 is the decoder address. R- Link to comment Share on other sites More sharing options...
Rog RJ Posted May 2, 2017 Share Posted May 2, 2017 Better to use the "Address Read" facility. This will read 4 digit and 2 digit addresses. CV1 only contains 2 digit addresses. If a decoder has been given a 4 digit address then CV1 will still contain a 2 digit address which may be nothing like the 4 digit address which is stored in CVs 17 & 18 with a marker bit set in CV29 to indicate that a 4 digit address is to be used. So if a 4 digit address is in use, it's pointless reading CV1 at all. Link to comment Share on other sites More sharing options...
Howbi Posted May 2, 2017 Share Posted May 2, 2017 You could of course just reset the decoder which will then revert to an address of 03 but all other CVs will be reset to factory default also..........HB Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 2, 2017 Share Posted May 2, 2017 Reset by writing 8 to CV8. you could of course do a simple test - read CV1 and try the value as the address. If it works, you're set, if not, it must be a long address. If long, then do your reset, much easier than mucking around figuring out CVs 17, 18 and 29. Link to comment Share on other sites More sharing options...
andys steam dayz Posted May 2, 2017 Author Share Posted May 2, 2017 Thank you everyone for your knowledge and advice. Link to comment Share on other sites More sharing options...
