debe45 Posted May 15, 2017 Share Posted May 15, 2017 I have a small DCC layout and thought that sound might be interesting. Do I add a sound decoder to the existing decoder or do I replace the DCC decoder with one containing sound, say TTS?.This may be a silly question but any and all advice would be much appreciated. Many thanks in advance. Regards DB Link to comment Share on other sites More sharing options...
Howbi Posted May 15, 2017 Share Posted May 15, 2017 @DB.............Assuming you loco has an 8 pin socket you would replace the existing decoder with a suitable Hornby TTS decoder and find a suitably secure position for the speaker...........you can always change the speaker for a small 'sugarcube' speaker if space is limited...........HB Link to comment Share on other sites More sharing options...
2e0dtoeric Posted May 15, 2017 Share Posted May 15, 2017 Doesn't HAVE to be TTS, if you have deeper pockets!For twice as much, you get a lot more noises that sound more realistic. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 15, 2017 Share Posted May 15, 2017 debe45, just to reinforce what HB has said. If you think about it logically, the sound decoder has to replace the normal non sound decoder, so that the sounds the decoder make are synchronised to the loco (motor) movement. Just for balance, there are sound products at the very budget end of the market that are NOT decoders (thus they do indeed supplement the existing decoder). However their sounds are very limited and basic. The normally accepted definition of a sound decoder is a decoder that performs BOTH sound AND motor control. Link to comment Share on other sites More sharing options...
debe45 Posted May 17, 2017 Author Share Posted May 17, 2017 Thanks Chris, Howbinman and O2E.I might just try TTS Regards DB Link to comment Share on other sites More sharing options...
