Ard Lochan Posted May 21, 2017 Share Posted May 21, 2017 I have two recent additions namley a class A4 Sir Murrough Wilson and a class P2 Cock `o` the North, Both are fitted with 8 pin dcc, both Hornby. Both run fine on default setting of 3. when I program them to a different number, eg 20 and 21, the A4 runs very slowly and the p2 just sits there trying to go. If I write cv 8 to both which reset them to default 3 they are fine and run as they should. I an using a Gaugemaster Prodigy 2 controller. I have 18 other Hornby DCC and they are no problem. Any Ideas, Please, Regards, Neil. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 21, 2017 Share Posted May 21, 2017 Welcome to the forums Ard. Try swapping the decoders into other locos and tell us whether the fault follows the decoder or stays with the loco. Link to comment Share on other sites More sharing options...
morairamike Posted May 21, 2017 Share Posted May 21, 2017 Are you programing on the MAIN track or on the Program Track. If on the MAIN are all the other locos removed when you are doing the address setting. Link to comment Share on other sites More sharing options...
Ard Lochan Posted May 21, 2017 Author Share Posted May 21, 2017 Thank you both for replying, I have just sorted it, oddly enough if I program the loco with just its address and omit the sv acc dec and tv steps the locos now respond to their allocated new address. Regards, Neil Link to comment Share on other sites More sharing options...
RDS Posted May 21, 2017 Share Posted May 21, 2017 Glad you sorted it out Neil, Thanks for letting us know the outcome. Link to comment Share on other sites More sharing options...
