fac Posted June 11, 2017 Share Posted June 11, 2017 While using speech to operate my railway i do not have direct vision to my laptop.As the speech command is returned with confirmed i did not see this as a problem.However the confirmed statement only confirms a command , if the command was not as one intended there is no audio way of telling only by screen vision. If i have issued an engine speed command , and then several point commands later (i have a large point indicator board seperate to screen which is always visible) return to further altering the engine speed (having forgotten which of the engines i am operating), i have found that the engine i am watching is not the engine i have changed the speed on.(my error but quite catastrophic) Or i address an engine and the command hears it as a differant engine (due to occaisional speech error) but states confirmed (command is accepted) once again what is being programmed is different to expectation. Now i have emergency stops such that when i spot an error or derailment i can shut down the hardware instantly. I aim to solve the above problem by fitting a larger screen next to the point indicator board as a slave screen to the laptop screen so that i can check my speech commands as issued.. However i would have thought railmaster could repeat sound wise the essence of a command stating point or engine identity rather than just confirmed. Then we would know that the command issued was the command applied . Link to comment Share on other sites More sharing options...
St1ngr4y Posted June 11, 2017 Share Posted June 11, 2017 That sounds like a great idea. I think you should add this to the Desirable Features thread. Ray Link to comment Share on other sites More sharing options...
