Andy7 Posted June 25, 2017 Share Posted June 25, 2017 I'm newbie to this:) after searching online I can't find instructions anywhere for the r3082 (dcc ready) and how to open it up, it seems be different to regular trains I'm not sure how to pop it open so can fit a DCC chip. Any info be great! Cheers Link to comment Share on other sites More sharing options...
walkingthedog Posted June 25, 2017 Share Posted June 25, 2017 It won't pop open you will need to remove a screw (maybe two) from the underside of the loco. Did it not come with a service sheet? Link to comment Share on other sites More sharing options...
Howbi Posted June 25, 2017 Share Posted June 25, 2017 Andy...............I think you will find a screw in the chassis hidden by the front bogie.........it may be possible to move the bogie to one side sufficiently to reach the screw, if not, remove the bogie first.........the boiler then lifts up while you pull chassis forwards to release the rear of the chassis from lugs under the cab.......that is if the decoder socket is in the loco.......if there a wires linking to the tender then there are screws in the tender chassis to release the body to reach the socket..........HB Link to comment Share on other sites More sharing options...
Howbi Posted June 25, 2017 Share Posted June 25, 2017 Service sheet 306c might be useful..........HB Link to comment Share on other sites More sharing options...
96RAF Posted June 25, 2017 Share Posted June 25, 2017 page three of maintenance sheet downloads area - hog warts castle class.cant give you a direct link as my hotel internet is rubbish...rob Link to comment Share on other sites More sharing options...
Howbi Posted June 25, 2017 Share Posted June 25, 2017 Here's the link........ https://www.hornby.com/uk-en/downloads/view/index/cat/16/?p=3 Link to comment Share on other sites More sharing options...
walkingthedog Posted June 25, 2017 Share Posted June 25, 2017 I think you have to remove the screw that holds the draw bar (the connector to the tender) in place. There is a youtube video of the loco being serviced. Link to comment Share on other sites More sharing options...
Chrissaf Posted June 25, 2017 Share Posted June 25, 2017 The information posted below is taken from this Hogwarts Loco Maintenance PDF (PDF download link courtesy of RAF96)https://www.hornby.com/uk-en/downloads/view/download/item/216./media/tinymce_upload/408e4047e5e6e186cbe95737a1febe77.jpg./media/tinymce_upload/3ab62dd0a9b2026e6b1f1cafa2743723.jpg. Link to comment Share on other sites More sharing options...
Fishmanoz Posted June 25, 2017 Share Posted June 25, 2017 Be very careful not to overtighten the draw bar screw as it can cause the brass fitting into which the screw goes to break out of the body. Once that happens, it's new body time. Link to comment Share on other sites More sharing options...
81F Posted June 28, 2017 Share Posted June 28, 2017 Two cautionary notes to add to the above. Note the spring shown in 1a, this is under quite a bit of compression so can fly when the chassis removed. I think I must have spent more time crawling on the floor looking for these springs than fitting the chips! Another is that when you lift out the chassis (with the loco upside down the cylinders will drop out unless they're supported. It's not impossible to slide the pistons back in and put it back but it is a pain that can and is best avoided. Also the pipe behind the handrail on the boiler is VERY fragile Also make a note of which slot below the cab the draw bar fits. Link to comment Share on other sites More sharing options...
81F Posted June 28, 2017 Share Posted June 28, 2017 Trying to refit the body without the spring in 1a flying across the room is also a challenge. I find the best technique is to reassemble the loco upside down with just the spring in place but no drawbar.or rear screw without dropping the cylinders.. Next gently tighten the front screw so that it just holds the body in place so that the cylinders do not fall out. Then ising somethng ver thin and flat (like a scalple blade) lever the spring down (note loco still upside down)through the slot the draw bar fits tghen slide both parts of the draw bar in above the blade. Finally ensure the hole in the draw bar lines up with the trapped nut in the body and hole in chassis and insert the rear screw without overtightening. You can then tighten the front screw if necessary. Link to comment Share on other sites More sharing options...
