Nictor Posted June 29, 2017 Share Posted June 29, 2017 Anyone know if they are identical? I want to swap a body shell from a Lima maroon parcel car to a hornby one that has a damaged body but DCC ready unit? Don't want to mess about too much. Link to comment Share on other sites More sharing options...
The Doc Posted June 29, 2017 Share Posted June 29, 2017 I don't own this model but I've got a few of the Hornby ex-Lima diesels and in each case the body is identical to the previous Lima version, only the motor bogie has been altered, so the bodies should be a direct swap. Link to comment Share on other sites More sharing options...
Jimbo1707820979 Posted June 29, 2017 Share Posted June 29, 2017 Hi NictorI have already done a similar swap and there was no problem at all. Very easy. Link to comment Share on other sites More sharing options...
Mahoganydog Posted June 29, 2017 Share Posted June 29, 2017 Hi Nictor, I've just done the exact thing you have. Direct fit with zero alterations required. I do however advise that you re-use the old Lima body screws and try and start them in the original thread. Remember, you're working with plastic that could be thirty years old on the Lima body and it could be fragile. Oh, and don't forget to pull the buffers out before trying to remove the body. These go through the body and into the chassis. I would hate to guess how many have broken the bodies over the years by missing this and trying to force it to come off! Jim Link to comment Share on other sites More sharing options...
Nictor Posted June 30, 2017 Author Share Posted June 30, 2017 Many thanks all. T'was as I suspected. DCC chipped a hornby one so I know about the buffers. They are a tad fragile so I bought a spare set. Link to comment Share on other sites More sharing options...
