Tuipiri Posted December 27, 2011 Share Posted December 27, 2011 Hi all, hope you had a lovely Christmas 2011. I have a problem with my Elite. I downloaded Railmaster (no probs), linked to Elite (didn't work) via PC and USB connection, and then got off railmaster. Now when I turn on my Elite, the green light comes on flashing, but no normal startup on the screen. Instead, it is blank. (elite is now NOT connected to usb or pc at all).Because I can't see the screen, I cannot even go to any menus on the elite. Can anyone suggest a solution? Many thanks, Tuipiri. Link to comment Share on other sites More sharing options...
Mike_G Posted December 27, 2011 Share Posted December 27, 2011 Tuipiri said:Hi all, hope you had a lovely Christmas 2011. I have a problem with my Elite. I downloaded Railmaster (no probs), linked to Elite (didn't work) via PC and USB connection, and then got off railmaster. Now when I turn on my Elite, the green light comes on flashing, but no normal startup on the screen. Instead, it is blank. (elite is now NOT connected to usb or pc at all).Because I can't see the screen, I cannot even go to any menus on the elite. Can anyone suggest a solution? Many thanks, Tuipiri.Have you tried resetting the elitedid the elite ever connect to internet or railmastermaybe it was trying to upgrade and failedmake sure you have down loaded all the firmware upgradesfor both the elite and railmasterif all failsfollow the directions and reprogram the elite make sure the drivers are correct for your operating systemthere are known problems with win7try XP (recomended) or vistargdsMike Link to comment Share on other sites More sharing options...
Augustus Caesar Posted December 28, 2011 Share Posted December 28, 2011 See my reply on the other post you located elsewhere. Much the same as the above referring to firmware reinstallation.If running Windows 7 right click the setup file and give administrator rights (run as administrator) and tick the check box that enables you to run under Service Pack 3 for XP compatibility. This works for Win 7 32 and 64 bit. You may need to give it a few goes though depending upon your system. I gave it three goes and it worked after that on a friend's amchine.Do not connect through a USB hub. Link to comment Share on other sites More sharing options...
