Forum-1211528 Posted July 13, 2017 Share Posted July 13, 2017 i have fitted a Tri-ang B12 with a DCC CONCEPTS 6 pin chip this seems to work with the XO4 motor inside this loco so i might convert other Tri-ang locos to DCC what locos have you converted or are considering converting? Link to comment Share on other sites More sharing options...
96RAF Posted July 13, 2017 Share Posted July 13, 2017 ColinThe decoder spec says 750mA to 1A so should be able to handle an X04 motor OK.Let us know if it handles the load in normal layout service.Rob Link to comment Share on other sites More sharing options...
Forum-1211528 Posted July 13, 2017 Author Share Posted July 13, 2017 ColinThe decoder spec says 750mA to 1A so should be able to handle an X04 motor OK.Let us know if it handles the load in normal layout service.RobHi Rob its the Early BR green B12 with BRITISH RAILWAYS on the tender it runs fine with a train of 20 Gresley coaches and would pull more! i have the BR black B12 61572 but theres a SYCROSMOKE smoke unit inside that loco so this loco will stay ANALOGUE as i dont want a DCC chip in that when this B12 has a smoke unit! Link to comment Share on other sites More sharing options...
96RAF Posted July 14, 2017 Share Posted July 14, 2017 Thanks for the feedback Colin.Sounds like that decoder is a good 'un for the older locos.Rob Link to comment Share on other sites More sharing options...
Forum-1211528 Posted July 14, 2017 Author Share Posted July 14, 2017 Thanks for the feedback Colin.Sounds like that decoder is a good 'un for the older locos.RobHI Rob the DCC CONCEPTS six pin decoder is suitable for any X04 fitted loco from the Seventies but any split framed locos from the 1950s will prove a big mistake as these will simply FRY any chip you put in it as the whole underframe is live so DCC on these simply can never ever be as a sixty year old loco shouldnt have DCC at all!!Colin Link to comment Share on other sites More sharing options...
RDS Posted July 15, 2017 Share Posted July 15, 2017 I have previously fitted DCC to a split frame Loco. It wasn't easy and required a lot of careful insulating but it worked. I can't remember which Loco it was, other than I think it was a Bachmann and I don't have it any longer. Link to comment Share on other sites More sharing options...
The son of Triangman Posted July 15, 2017 Share Posted July 15, 2017 I've chipped loads of Tri-ang locos, ideally the decoder should be able to handle a stall current of 1 Amp.Hattons do a nice inexpensive decoder capable of taking up to 1 Amp for around £12 and it's ideal for the job.DCC Fitted Tri-ang Hymek /media/tinymce_upload/3ca09a2ba48bb717d490e6cccc67c434.jpg Link to comment Share on other sites More sharing options...
Forum-1211528 Posted July 15, 2017 Author Share Posted July 15, 2017 I have previously fitted DCC to a split frame Loco. It wasn't easy and required a lot of careful insulating but it worked. I can't remember which Loco it was, other than I think it was a Bachmann and I don't have it any longer.A Bachmann loco should be fine converting to DCC its the Tri-ang fifties split frame locos that simply cant be isolated to allow the chip to work like the BR black saddle tank 748 its not worth the hassle im not interested in a DCC chip in that loco as its a great runner an analogue as this DCC lark is a Yank idea and im not a big fan of it on old locos so i dont bother with it on them!Colin Link to comment Share on other sites More sharing options...
Sultan Posted July 17, 2017 Share Posted July 17, 2017 I have previously fitted DCC to a split frame Loco. It wasn't easy and required a lot of careful insulating but it worked. I can't remember which Loco it was, other than I think it was a Bachmann and I don't have it any longer.Do not be put off fitting DCC to split frame locos. I have done quite a few Bachmann and mainline locos including a Mainline 03. There is plenty of information on the web including this usefull site Bromsgrove Models. https://clarahost.clara.net/www.bromsgrovemodels.co.uk/mainline03dccinstr.htm Link to comment Share on other sites More sharing options...
