DEREK123 Posted July 18, 2017 Share Posted July 18, 2017 I am certain this is a silly question but I feel I should ask as I don't want to create a disaster !! What are the problems ( if any ) in running a DCC ready but chipped loco on a 12V DC layout ? - using a standard gaugemaster Model DS controller. Is this sensible ?I ask as I am wanting to get prepared for a layout conversion , running a newly purchased s/h Hornby King George 1 loco (R2544) ... what chip would you recommend I buy ?ThanksDerek Link to comment Share on other sites More sharing options...
Howbi Posted July 18, 2017 Share Posted July 18, 2017 Derek..........if you are running a DC layout why have a decoder in the loco........just fit a blanking plate and run it as native DC............When you get a DCC controller then is the time to fit a decoder.........the Hornby R8249 decoder is perfectly adequate for the job...........HB Link to comment Share on other sites More sharing options...
2e0dtoeric Posted July 18, 2017 Share Posted July 18, 2017 If the loco is dcc ready, it is NOT a DCC loco, it is just ready to have a decoder plugged in.It WILL have a blanking plate plugged in, to connect the rails to the motor. If you don't know differently, the plate can be mistaken for a decoder. Link to comment Share on other sites More sharing options...
DEREK123 Posted July 18, 2017 Author Share Posted July 18, 2017 Derek..........if you are running a DC layout why have a decoder in the loco........just fit a blanking plate and run it as native DC............When you get a DCC controller then is the time to fit a decoder.........the Hornby R8249 decoder is perfectly adequate for the job...........HBThanks for your speedy reply HB ... as I build the new DCC layout I felt it would be nice to test it " in progress " but still be able to use the loco on the DC layout without removing the chip .... is that good practice or will I damage the chip ?Derek Link to comment Share on other sites More sharing options...
DEREK123 Posted July 18, 2017 Author Share Posted July 18, 2017 Hi EricThanks ... I do believe there is a blanking plate so yes it is DC ready .... please see my reply to HB... CheersDerek Link to comment Share on other sites More sharing options...
walkingthedog Posted July 18, 2017 Share Posted July 18, 2017 DCC locos run beautifully on a DC layout as long as DC running hasn't been disabled. Almost all new DCC locos will run without a problem. Link to comment Share on other sites More sharing options...
DEREK123 Posted July 18, 2017 Author Share Posted July 18, 2017 Hi WTDThanks for that ... now all I need to know is " what and how is DC running disabled " ?Derek Link to comment Share on other sites More sharing options...
walkingthedog Posted July 18, 2017 Share Posted July 18, 2017 If you have a DCC controller you can disable DC running. New locos with fitted decoders will be OK but some DCC users disable DC running because they don't need it. So if you buy a second hand DCC loco it might have been disabled. If it has been disabled you need to get it enabled by somebody withh a DCC controller. Link to comment Share on other sites More sharing options...
Howbi Posted July 18, 2017 Share Posted July 18, 2017 This link will help to understand the intricacies of CV29..........it is interactive so you can tick or untick the boxes to get the result required........... http://www.2mm.org.uk/articles/cv29%20calculator.htm ............HB Link to comment Share on other sites More sharing options...
DEREK123 Posted July 18, 2017 Author Share Posted July 18, 2017 Thanks WTD & HBGot it !! .... cheers .... you are very hepfulDerek Link to comment Share on other sites More sharing options...
