ashmash Posted July 29, 2017 Share Posted July 29, 2017 Just recieved my first loco with TTS sound. Im using Hornby Select controller and instruction booklet says press F1 to turn sound on and also lists other "F" varients for other sounds. How do you access this on a Select controler as I can only find the Function button which is press for on or off and this does not seem to turn on the much anticipated sound.Any suggestions will be appreciated Link to comment Share on other sites More sharing options...
96RAF Posted July 29, 2017 Share Posted July 29, 2017 You press number 1 then the Function button. It's all in the manual. This turns F1 on. You do it again to turn it off. Ditto any other function. Of interest what is the sequence of numbers on screen as your Select starts up. See the manual first pages for an explanation. If you want to be able to access all TTS functions then your Select needs to be at version 1.5. Rob Link to comment Share on other sites More sharing options...
ashmash Posted July 29, 2017 Author Share Posted July 29, 2017 On power up the sequence is 15 , 30 , 03Thanks for your advice, I will give it a go I read it as press function button then the number 1 Link to comment Share on other sites More sharing options...
Chrissaf Posted July 29, 2017 Share Posted July 29, 2017 Your power-up sequence indicates that you have the current version 1.5 firmware. Function control procedures were different in the previous 1.4 & 1.3 firmware versions. You are using the wrong procedure, just pressing the Function button and nothing else, is the shortcut for turning on lights of the locos fitted with directional lights (F0). To turn on and off other Functions (F1 to F28) you use multiple keys. The appropriate page from the firmware version 1.5 manual is replicated below:.Note that you enter the Function number FIRST, before pressing the Function button, not the other way round. Function number 1 (F1) is used to turn the TTS sound on and off. Then other higher function numbers control individual sounds appropriate to your particular model as listed on the loco instruction sheet../media/tinymce_upload/2fca1276ff03c4c42c094171222eaea8.jpg. Link to comment Share on other sites More sharing options...
96RAF Posted July 29, 2017 Share Posted July 29, 2017 OK your Select is at the latest version so all TTS functions should work per the book. Link to comment Share on other sites More sharing options...
ashmash Posted July 29, 2017 Author Share Posted July 29, 2017 Thank you all for your positive support, Im an old un and find this technology a bit challenging but its great fun when it it works Link to comment Share on other sites More sharing options...
