MarkNZ Posted August 5, 2017 Share Posted August 5, 2017 Hi AllI'm trying to change the address on a Bachmann 37 loco which is fitted with a Bachmann decoder. However after numerous attempts I can't change it from the default 0003. I have another 37 (Same configuration) which changed fine. Could it be a dodgy decoder? It runs well and all the cab lighting works so not sure what it could be?Any help or suggestions would be most appreciated either on the decoder, the Elite or both. I'm pretty sure it's not operator error as I've managed to change the other one, but I could be wrong!CheersMark Link to comment Share on other sites More sharing options...
96RAF Posted August 5, 2017 Share Posted August 5, 2017 Try a reset of the decoder that is being a problem. Write value 8 to CV8 on the programming track. As you say in another post that you are new to DCC and may not be fully up to speed on the Elite it is simply a case of following the flow chart in the manual which mimics the screen menus and shows the options on any screen. However as you have managed to address one decoder OK then it seems you have the procedure correct. Some Bachmann decoders can be fussy to program with Hornby kit but the later the revision state of your Elite (check the version on screen at startup) the better as each Elite update supports more and more 'alien' decoders. Rob Link to comment Share on other sites More sharing options...
MarkNZ Posted August 5, 2017 Author Share Posted August 5, 2017 Try a reset of the decoder that is being a problem. Write value 8 to CV8 on the programming track. As you say in another post that you are new to DCC and may not be fully up to speed on the Elite it is simply a case of following the flow chart in the manual which mimics the screen menus and shows the options on any screen. However as you have managed to address one decoder OK then it seems you have the procedure correct. Some Bachmann decoders can be fussy to program with Hornby kit but the later the revision state of your Elite (check the version on screen at startup) the better as each Elite update supports more and more 'alien' decoders. RobThanks Rob, I am most certainly on a steep learning curve in regards to DCC. I will do what you recommend, fingers crossed.Mark Link to comment Share on other sites More sharing options...
Rog RJ Posted August 5, 2017 Share Posted August 5, 2017 Another thing you can try is resetting the Elite itself. Been known to cure all sorts of problems, though you will lose any loco names you have entered, if you have entered any. Link to comment Share on other sites More sharing options...
Chrissaf Posted August 5, 2017 Share Posted August 5, 2017 Don't forget, if resetting the Elite. Make sure it restarts in 'Standard' mode and not 'Classic'. If it starts in 'Classic' mode after a reset, change it back to 'Standard' using the Elite menu system. Instructions are in the Elite manual. Link to comment Share on other sites More sharing options...
