Nickciren Posted August 8, 2017 Share Posted August 8, 2017 I have a hornby select and need to do a loco decoder reset to manu settings ( write 8 to CV 8 ) how do you do it? Link to comment Share on other sites More sharing options...
Chrissaf Posted August 8, 2017 Share Posted August 8, 2017 Unfortunately the Select does not support a general CV writing feature. It can write to a limited number of CV controlled configuration elements such as, for example, the DCC Address, Acceleration and Deceleration, but this is through a dedicated menu driven interface sub-system. It does not however have any capability to write to other CVs such as CV8..Note that the 'reset option' in the 'Select Menu' is a factory reset for the Select controller itself and not the factory reset of an external decoder as one would find in a loco..PS - You are correct in that to reset a decoder you need to write value 8 to CV8. There is no other way or workaround. Link to comment Share on other sites More sharing options...
