Forum-1211528 Posted August 10, 2017 Share Posted August 10, 2017 When it comes to Tri-ang locos what can and cant be DCC fitted? What is simply sixty years old and you wouldnt put a chip inside it as it would fry the chip, what has a SYNCROSMOKE unit inside that means you put smoke oil into that unit as the unit is exposed unlike say SEUTHE smoke units means these locos can never ever be DCC fitted as one drop of smoke oil onto the DCC chip would mean DEADDCC CHIP! So what else have you DCC fitted that is Tri-ang? 😎 Link to comment Share on other sites More sharing options...
trainlover23 Posted August 11, 2017 Share Posted August 11, 2017 All locos can be DCC fitted providing you get the correct chip. In aother post you said " Stuff DCC I don`t want to know it". now you want to know all about it. Also other posts by you have alluded that you use DCC so make your mind up Link to comment Share on other sites More sharing options...
