Backafter5 Posted August 17, 2017 Share Posted August 17, 2017 hiwhen switched on the R8247 decoder fires points once and then gets hot and does not appear to recharge. Have tried it with elink and have also connect to select and programming track same results any advice ps just bought this decoder Link to comment Share on other sites More sharing options...
Rog RJ Posted August 17, 2017 Share Posted August 17, 2017 Sounds like it may be faulty. I would contact the supplier about returning it. Link to comment Share on other sites More sharing options...
mikejj101 Posted August 17, 2017 Share Posted August 17, 2017 Double check that you have wired it correctly.I had a similar issue and discovered that by reversing the wiring corrected the issue.Mike Link to comment Share on other sites More sharing options...
Backafter5 Posted August 18, 2017 Author Share Posted August 18, 2017 Thanks all who answered but as I am new to model railway I had some how programmed the decoder to stay on instead of just giving a burst of power but lots of browsing it suddenly became clear what I was looking at in railmaster. So that problem solved onto next trains sticking on points. 😎 Link to comment Share on other sites More sharing options...
mikejj101 Posted August 18, 2017 Share Posted August 18, 2017 Glad you sorted the decoder problem.With regard to trains sticking on points - double check with your meter that you are getting power to all parts of the point. I have problems with older locos where the power pick up is only from two or four wheels. Link to comment Share on other sites More sharing options...
