Fireman_Ian Posted August 23, 2017 Share Posted August 23, 2017 A few of the buttons on my Elite keypad don't work very well and need an extra hard press to get them to register. If anyone has had this problem is there a fix or do I need to replace the unit? Link to comment Share on other sites More sharing options...
Chrissaf Posted August 23, 2017 Share Posted August 23, 2017 Rob (RAF96) has posted on this issue several times. One quite recently. Click on his name to see his posts listed in date order (probably easier than a general forum search). Or just wait for Rob to see this post and respond. The fix does, of course, require you to do some fairly major Elite dismantling. Link to comment Share on other sites More sharing options...
96RAF Posted August 23, 2017 Share Posted August 23, 2017 Here's the link Ian to the reply I gave to you then.... https://www.hornby.com/uk-en/forum/controllers/?p=2/#post-218481 Rob Link to comment Share on other sites More sharing options...
Fireman_Ian Posted August 23, 2017 Author Share Posted August 23, 2017 Many thanks, I missed your post under "controllers" I shall follow your advice and report back. Link to comment Share on other sites More sharing options...
WilliamDavid Posted August 24, 2017 Share Posted August 24, 2017 I had a dicky No 5 on mine. I gave it loads of presses as suggested in the link. Worked a treat.Thanks for that Rob. Link to comment Share on other sites More sharing options...
