52train Posted September 7, 2017 Share Posted September 7, 2017 I am going to get some sapphire decoders so I can have asymmetric braking but I have put dropers from all track sections . So I am guesing I will have to fit diodes to track and the bus wire unless you know diffrent. AS usual any help. Link to comment Share on other sites More sharing options...
96RAF Posted September 7, 2017 Share Posted September 7, 2017 Go to my signature linked website, look at the wiring diagrams bit and make your own Lenz BM1 equivalent 5-diode module for pennies. This connects across a break in the right hand rail in the direction of travel, with a parallel override switch if desired - .e.g.red/green signal. You then set the Sapphire up to respond to uni or bi-directional travel per the Sapphire manual.Again I have pictures but cant upload them in the present duff web-site conditions. You should also read the Lenz website ADCC section.Rob Link to comment Share on other sites More sharing options...
