morairamike Posted September 12, 2017 Share Posted September 12, 2017 OK as some of you will have seen I modified and fitted my recently delivered A4 TTS decoder to my Mallard testerday. This afternnon O extended the track I have to run her a bit further. After 1 hour the sound of the "Loco running - exhaust chuffing started to be overlaid with a crackling sound, (bit like a wood log burning). I tried a CV8 reset data 8 but that made no difference I tried a CV8 reset sound levels data 5, again no difference. I then turned all the individual sound CVs to 0 to see if the crackle went away. It does but only when CV161 is at 0. I sent Hornby contact us a message about this and await the reply. Anyone else on here sufferred from distortion/strange sound on TTS Link to comment Share on other sites More sharing options...
Howbi Posted September 12, 2017 Share Posted September 12, 2017 It may the speaker at fault, others have had to replace usually with a sugar cube type.......worth a try.........HB Link to comment Share on other sites More sharing options...
morairamike Posted September 12, 2017 Author Share Posted September 12, 2017 I have 3 on order a/w delivery. it only happens on the one sound channel, still I'll see what happens Link to comment Share on other sites More sharing options...
morairamike Posted September 13, 2017 Author Share Posted September 13, 2017 As I am an engineer I decided to look into the problem further. Yes you were correct it's the Hornby supplied speaker. I found an 8 ohm when in one of those sound birthday cards and when that was used no crackle heard. Then to make double sure I used an 8 ohm speaker from a computer speaker set. Again no crackle. I do have sugar cube speakers on oreder. What I did find with the computer speaker that at a volume CV177 @ 8 (max) the loco cut out after a few chuffs, possible the current draw was too large. OK on vol 4. I wear hearing aids and vol 4 (default) is loud enough for me. So possible that the original speaker didn't like it when I used volume 8 on it. Link to comment Share on other sites More sharing options...
Howbi Posted September 13, 2017 Share Posted September 13, 2017 Thanks for the very useful feedback...........HB Link to comment Share on other sites More sharing options...
