Stuartlanarks Posted December 30, 2011 Share Posted December 30, 2011 I am in the process of converting my layout to DCC. I have noticed that some of my points are setrack. Can I merely insert the clips in these or would it be best to replace with normal? I will also need 2 decoders (I think) as I have 8 points. Is the select controller capable of handling more than 1 decoder?Many Thanks Link to comment Share on other sites More sharing options...
Flashbang Posted December 30, 2011 Share Posted December 30, 2011 HiYou can simply add the Hornby Digital Point Clips - two per point, to any Hornby or P**o Setrack point for DCC operation.You can have far more than two accessory decoders with the Select. In fact it can feed 10 accessory decoders.Stuartlanarks said:I am in the process of converting my layout to DCC. I have noticed that some of my points are setrack. Can I merely insert the clips in these or would it be best to replace with normal? I will also need 2 decoders (I think) as I have 8 points. Is the select controller capable of handling more than 1 decoder?Many Thanks Link to comment Share on other sites More sharing options...
Stuartlanarks Posted December 30, 2011 Author Share Posted December 30, 2011 Thanks,So If I connect more than one decoder, I just assume that I would follow the addressing sequence that's in the instructions? IE 61,62,63,64 for first then 65,66 and so no for the second? Link to comment Share on other sites More sharing options...
