Disco Posted January 3, 2012 Share Posted January 3, 2012 Hi allCould be a long one, but basically we have Mixed Freight Set (Oval) and Extension Packs A,B,C and F.At the moment I have the large Hornby TrakMat ( http://www.newrailwaymodellers.co.uk/images/hornby-2007/train-sets/trakmat-lrg.jpg )When fully complete, this holds 8 points - 7 main ones, and 1 I shall model into the set when creating an extra siding/fidle yard. Basically. my question is what EXACTLY do I need to be able to control these 8 points digitally, but at the same time, keep costs down.Do you need a Hornby Points Decoder (£30) and then a surface mount/hidden motor with shell PER point? If so, I'm looking at almost £10 per point plus TWO decoders at £30 each? Can someone tell me if that is right, and point me into the right direction to purchase such items that I will need. Link to comment Share on other sites More sharing options...
Doodle009 Posted January 3, 2012 Share Posted January 3, 2012 Hi,You will need two decoders, one points decoder will do four points. A point motor for each point, I prefer the surface side mounted Peco PL-11's as I've had issues with the Hornby point motors not being strong enough to throw the point blades back and fourth. You haven't said whether you are running a DC or a DCC layout? If it is DC I'd imagine you will also need a point lever switch per point too. I run a DCC layout using a digital controller handset. Andy Link to comment Share on other sites More sharing options...
Mike_G Posted January 4, 2012 Share Posted January 4, 2012 HiThats not quite right info there1 You do need 1 point motor for each point is correctwhat type you get depends on what you whant it to doand how your track is set up ( baseboard wise )2 Point decoders,, there are several tpes for thisbut assuming you are talking HornbyThe Hornby decoder indeed has 4 outletsbut1 out let can control more than 1 pointIf you have a situation were 2 points need to be thrown to make a routethen they can both be thrown by one outlet at the same timeinfact i have occasion were 1 outlet is throwing 4 points to form a routeyou will also need a point lever and the wiringnow i dont know were you will buy the levers or how much you will pay for thembut before you buy them add the price up (cost of 8 )it could be cheaper to buy the Railmaster and then control them direct from thecomputer with a mouse click ( no levers required )you already have the computer to run it on else you would not be here onthis sitedo your sums firstRgdsMike Link to comment Share on other sites More sharing options...
Rog RJ Posted January 4, 2012 Share Posted January 4, 2012 Mike_G said:you will also need a point lever and the wiringRgdsMikeI don't understand why point levers are being included.I'm assuming by point lever you mean the R044 passing contact lever switch. If the points are to be operated under DCC control from a decoder then the points are operated from the controller (Select or Elite for instance) and no point lever is needed and can't be used if a Hornby points decoder is used.I know there are other makes of decoder that do allow switches to be used for manual point operation alongside DCC operation but we're talking about Hornby here.So, what's needed (for DCC operation) is a point motor for each point. Either the R8014 or R8243 type can be used. The R8243 is easier to fit but can't be hidden under the baseboard. The R8014 can be used under the baseboard or on top of the baseboard if mounted in the R8015 point motor housing.One point decoder is required for every four point motors unless you have a situation where two point motors can be operated at the same time, such as a crossover from one track to another where two points are operated at the same time.Of course you have the alternative option of not operating the points by DCC control. Just because you are using DCC to control the trains doesn't mean you have to use it to operate the points - you can still operate the points manually, by switches, by stud and probe or by push bottons Link to comment Share on other sites More sharing options...
Rog RJ Posted January 4, 2012 Share Posted January 4, 2012 That should be "push buttons" Link to comment Share on other sites More sharing options...
Disco Posted January 4, 2012 Author Share Posted January 4, 2012 see, I get various answers from different people and thats where it gets confusing.We on DCC upto 8 points, cheap as possbile, but obviously in keeping with the digital thing!!1x R8243 per point and 1x Hornby Decoder per 4 points is what I was told somewhere along the line (no pun!) Link to comment Share on other sites More sharing options...
Rog RJ Posted January 4, 2012 Share Posted January 4, 2012 Then it's make your mind up time. Link to comment Share on other sites More sharing options...
Disco Posted January 4, 2012 Author Share Posted January 4, 2012 so tell me Rog, is what Ive been told above your post correct?ie: 1x R8243 per point and 1x Hornby Decoder per 4 points Link to comment Share on other sites More sharing options...
Rog RJ Posted January 4, 2012 Share Posted January 4, 2012 Yes, that will work. Link to comment Share on other sites More sharing options...
Mike_G Posted January 4, 2012 Share Posted January 4, 2012 you will find that trying to operate 8 points + maybe 2 engines on the elite can be a bit frustrating,, time you remenber the correct address for the point out of 8 you wish to change ,,, select its number on the elite and activate it the train will have done 1 or 2 circuits around the track and either crashed or gone the wrong way.the elite is quite good now its been updated but it still is a dog to use like you proposein fact most controlers would be the same,,, belive me even when you can see the layout on the screen and only have to click with the mouse,, it gets a bit heticanyway wish you luck what ever you end up doingrgdsMike Link to comment Share on other sites More sharing options...
RedRattler Posted January 5, 2012 Share Posted January 5, 2012 Hi disco, just wondering how you got on as you have the same set as me (mixed freight) which means a Select controller, and i have the same choice.did you get the decoders working and which type did you use (R8247 or R8216)? I still lean toward using switches for the reasons MikeG mentioned above (and a separate 4amp PSU) Link to comment Share on other sites More sharing options...
Disco Posted January 6, 2012 Author Share Posted January 6, 2012 I've got nowhere at the minute (due to time), but (due to cost, unless you can find them cheaper), i'm learning towards a Points Decoder (£30) and surface mounts (someone one on ebay is selling them for around £5.70 each which the cheapest I've seen themAtm, I only need 1 Points Decoder and 4 surface mounts, costing around £53. (i'll double this later in the year as we only have/need 4 actual points - but like I say, suggest a cheaper alternative, and I'll look at that too)PS: We are DCC as well. Link to comment Share on other sites More sharing options...
