Geoff 333 Posted January 12, 2018 Share Posted January 12, 2018 I recently purchased a loco with a Loksound V3 sound decoder pre fitted, I was told whats sounds were available from what funtion numbers etc. I re-numbered the loco as usual different from the standard ID of number 3 as usual but nothing worked. I read the CV values and managed to see that the ID did not change, I got the loco working but the sounds were not as expected. I also found that the Decoder info said it was a Loksound V4, strange. When converting another loco from non-sound to sound having purchased a TTS castle class decoder, Elink reported that the decoder is a Saphire decoder not a sound decoder. Elink did not recognise the TCS T1 decoder that was originally fitted. Although both locos do work the CV settings do not seem to be correct and also does not report on the CV settings that are relavent to that decoder. Can anyone shed any light on this problem? ThanksElink - Railmaster Pro - Toshiba laptop running windows 10Hornby Clun Castle with Loksound V3 decoder (New) - Reproted as V4 decoderHornby Cadbury Castle (old) with TTS Castle class decoder. - Reported as Saphire decoder Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 12, 2018 Share Posted January 12, 2018 Geoff, you seem to be reporting exactly the problems fixed by the latest version of RM. Download and install it from the link at the top of the RM forum. Link to comment Share on other sites More sharing options...
Geoff 333 Posted January 12, 2018 Author Share Posted January 12, 2018 Cheers fishmanoz , I will try it, although I recently de-registered my other laptop and changed to this one with a touch screen and installed from the cd I had. The first time I ran it, it installed the updated version. I will check version numbers first but will still have a go. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 12, 2018 Share Posted January 12, 2018 Don’t believe just version numbers Geoff, definitely download again. They make sneaky little changes without telling anyone so whenever you have problems, first download again. Link to comment Share on other sites More sharing options...
