johnnyboy349 Posted January 7, 2012 Share Posted January 7, 2012 Can someone help me, every so often railmaster stops my train from functoining on it's allocated number causing me to change it's number, but its still letting me operate sound functions and allow me to turn lights on and off but when i go to move the loco or even change the direction it fails to do so, but when i put it on the test bed and hook it up to my select controller everything works fine, but when i put it on the test bed and run it with the elite it doesn't work (as above). Link to comment Share on other sites More sharing options...
stevecamden Posted January 8, 2012 Share Posted January 8, 2012 The Elite needs to be reset, that will sort this out. Make sure that you run it in Standard mode before firing up Railmaster. Link to comment Share on other sites More sharing options...
johnnyboy349 Posted January 8, 2012 Author Share Posted January 8, 2012 I have reset the elite and it is on standard mode, I have also tried rstarting my computer and neither of these work, I have managed to run other trains with no problems, the same problem did occur once but after changing the loco adress it worked perfectly. Link to comment Share on other sites More sharing options...
stevecamden Posted January 8, 2012 Share Posted January 8, 2012 OK - then I would reset the decoder on the loco - write 8 to CV8 in Direct mode on the Programming track. This will put all the settings back to how you got it. 3 being the loco address by default so you might want to change that.Steve Link to comment Share on other sites More sharing options...
