martin_moore Posted February 18, 2018 Share Posted February 18, 2018 I have converted my hornby tender drive flying scotsman to dcc using a wired in 8 pin socket and a hattons dcr-8pin-01 decoder this works perfectly. When fitting a tts sound decoder R8106 nothing happens, when programming the tender drive cogs move slightly then nothing.My control system is gaugemaster prodigy advance 2 this is the second decoder i have tried with same responce Link to comment Share on other sites More sharing options...
jane1707819582 Posted February 18, 2018 Share Posted February 18, 2018 i would suggest you are overloading the tts decoder it has a capacity of 500 ma the hattons is 1100 ma peak 1600 ma perhaps your tender motor needs a good service / clean up ? Link to comment Share on other sites More sharing options...
mjb1961 Posted February 19, 2018 Share Posted February 19, 2018 Hi,,,,when you programimed the decoders address ,,,did you give it a long address as well a short one ,,I have a few tts locos and one of them refuses to work on the short address but works fine on the long address ,,,,,you could give that a try ,,mjb Link to comment Share on other sites More sharing options...
