Clansman Posted March 1, 2018 Share Posted March 1, 2018 Hi AllI have recently started using E link/Rail master.Having created my track plan and added an accessory decoder (ads8fx), all is working as it should.However there is a small problem that I'm unable to overcome.The pairs of points forming the fiddle yard roads/ loops are showing opposite indications and no matter how they are configured, they will not indicate correctly.Any advice is very welcome.My previous set up was Gauge master Prodigy with PC interface. Which I was reasonably happy with but wanted a better GUI.I have the standard insallation, not Pro Pack.Regards Link to comment Share on other sites More sharing options...
St1ngr4y Posted March 1, 2018 Share Posted March 1, 2018 Hi Clansman,Welcome to the Forum.If it is a passing loop with which you have a problem, then maybe this thread might help you... https://www.hornby.com/uk-en/forum/post/view/topic_id/6332/?p=2 Ray Link to comment Share on other sites More sharing options...
2e0dtoeric Posted March 1, 2018 Share Posted March 1, 2018 Try swapping the wires over on the point motors, if they are going the opposite way to the indicators. Link to comment Share on other sites More sharing options...
Clansman Posted March 1, 2018 Author Share Posted March 1, 2018 The point blades all operate correctly and are programmed to operate as pairs, in a conventional 8 road fiddle yard set up.The issue is solely in respect to the direction of travel indication on the track plan.EditJust read the separate thread and understood.I will get on with purchasing Pro Pack.Thanks All Link to comment Share on other sites More sharing options...
