collectors Posted March 15, 2018 Share Posted March 15, 2018 Hi, i want to use DCC Concepts ADS-8sx decoder for some point motors but 2 of the points are 16met away. I am trying to find out what cable size is recommended for this sort distance. The terminals on this ADS-8sx unit wont take anything over 1.0mm/17awg & i got the impression i should be using a slightly larger cable. Or am i getting over worried. Thanks for any help. 😆 Link to comment Share on other sites More sharing options...
Flashbang Posted March 15, 2018 Share Posted March 15, 2018 HiIn the UK its recomemnded to use 16/0.2mm equipment wire for all solenoid motor feeding.16/0.2mm is equal to AWG 20 or 0.5mm216 Mtrs is a long wire run, if you mean 16 Mtrs? can you not re position the Accessory decoder closer to the motors? Link to comment Share on other sites More sharing options...
collectors Posted March 15, 2018 Author Share Posted March 15, 2018 Hi thanks for the quick response, yes, its 16met, the layout is on a shelf in 2 rooms running around the walls, so longer runs couldn’t be avoided. If larger wire is needed for these two points i could run 2.5mm but would have to drop down to 1mm for the last few inches at the decoder. If i moved the decoder closer it would be catch 22 with the other points that are close & also haven’t really got a convenient spot for the decoder being a shelf layout. Link to comment Share on other sites More sharing options...
Flashbang Posted March 15, 2018 Share Posted March 15, 2018 Just a second thought! If you do mean a wire run length of 16 Mtrs then... Fit a three way terminal block close to the decoders terminals (one three way block for each solenoid motor) then wire from the decoders output terminals to one side of the block with wire which will fit into the decoders terminals, then use a heavier wire from the other side of the block out to the motor. At the motor end do the same, fitting a three way terminal strip block close to the motor and terminate the heavy wire then use suitable wire e.g.16/0.2mm or 20AWG from the block to the motor. Each ends smaller sized wires being no more than 6 inches or roughly 150mm long. Link to comment Share on other sites More sharing options...
hedley_reynolds Posted March 15, 2018 Share Posted March 15, 2018 Hi Collectors I had used 32/0.2 wire as I too had long runs and the size of the wire was recommended by dcc concepts for to use on the long runs but it‘s a little bit of a tight squeeze but if you twist the wire enough it does fit as I have used it for my ADS-8FX decoders Hedley Link to comment Share on other sites More sharing options...
collectors Posted March 17, 2018 Author Share Posted March 17, 2018 Hi, sorry if i looked rude not getting back, but as a newbie i am limited to two posting because of spam within 24 hours.Hi Headley, what sort of lenth was your runs in 18awg/ 1.0mm2/ 32/0.2. lol?Hi, Flashbang, i have also found some small terminals that may fit at TLC.https://www.tlc-direct.co.uk/Products/CTPINslashB.html?source=adwords&ad_position=1o1&ad_id=45425533757&placement=&kw=&network=g&matchtype=&ad_type=pla&product_id=CTPIN%2fB&product_partition_id=174053084227&test=finalurl_v2&gclid=CjwKCAjw-bLVBRBMEiwAmKSB8wPhOpT_XV0nnWKcWOX_-bRh1hjkA6nG2BGM7py5Vv5jZOAA0MOPuxoCa1UQAvD_BwE Link to comment Share on other sites More sharing options...
NormanQ4 Posted March 17, 2018 Share Posted March 17, 2018 When operating two points from one decoder port I removed a small number of strands from each cable to enable entry into the decoder terminal.I'm definitely not an electrical expert but surely this could be done with a single heavier cable and would give the same result as running a smaller gauge cable for 150mm to a terminal block. Link to comment Share on other sites More sharing options...
hedley_reynolds Posted March 18, 2018 Share Posted March 18, 2018 Hi Collectors some of my runs are about 6 1/2 ft to 8ft and some are double points to one port on the decoder and the instructions for the decoder or the point motors said what gauge wire for to use so being a newbie I had done what the instructions said and followed them but I have had no problems with doing it that way Hedley Link to comment Share on other sites More sharing options...
hedley_reynolds Posted March 18, 2018 Share Posted March 18, 2018 Hi Collectors I have just checked and it was the instructions for the decoder and it recommend that 32/0.2 was used for solenoid point motors with a minimum of 16/0.2 for short runs so I used the thicker one for what I call a long run Hedley Link to comment Share on other sites More sharing options...
collectors Posted April 20, 2018 Author Share Posted April 20, 2018 Hi every one, i am very sorry i didnt reply as i read your helpfull posts & forgot to say thankyouGreat help, thanks. Link to comment Share on other sites More sharing options...
