sorano74 Posted April 27, 2018 Share Posted April 27, 2018 Hi , I have a problem with my scalextric set powerd with the c8217 power base . Car both move without using the controller, when I press the trottle all the way down they stop and the red light on the power base dimms . Also cars move from left to right . Anyone had the same problem?thanks for help Link to comment Share on other sites More sharing options...
woodcote Posted April 28, 2018 Share Posted April 28, 2018 @sorano74 - Has the power base worked okay in the past? Or is it a new set that has had this problem since you got it? Does it happen on both lanes with both controllers? I had this problem once when a controller wire was shorting across the resistor - giving me full power when I should have had none. However, it would be very strange if this was happening in both controllers. Link to comment Share on other sites More sharing options...
sorano74 Posted April 28, 2018 Author Share Posted April 28, 2018 Hi Woodcote its a used set and cars move by themself on both tracks left to right full power without touching the controllers , tried with both controllers same result, onl when controllers are plugged in Powerbase Link to comment Share on other sites More sharing options...
woodcote Posted April 29, 2018 Share Posted April 29, 2018 @sorano74 - there is definitely a short-circuit somewhere in the powerbase (or possibly in both controllers) that is by-passing the controller resistors. It may be possible to fix it, but will probably need an experienced eye - do you have a slot car club near you where someone could take a look at the powerbase and the controllers? Otherwise, I think your best solution is to buy a new powerbase. Alternatively to return the set to the seller if you bought it recently and the transaction was covered by some form of consumer protection. Link to comment Share on other sites More sharing options...
sorano74 Posted April 29, 2018 Author Share Posted April 29, 2018 Ok Thanks I have another set coming with same power base and controllers ,I 'll swap theme and check ,Thanks for help Link to comment Share on other sites More sharing options...
