Eddieand0 Posted April 28, 2018 Share Posted April 28, 2018 HiI have recently acquired a Scalextric set 31 I believe from 1963.As it has no transformer with it what is the latest model I could purchase from eBay.It requires a 2 amp 12 volt DC transformer/receiver. Link to comment Share on other sites More sharing options...
woodcote Posted April 28, 2018 Share Posted April 28, 2018 Hi Eddie - From the look of the Scalextric Collectors Guide website, the set 31 is from 1966-67 and came with the little Porsche and BRM F1 cars plus a figure-of-eight track. I have a 1960s transformer from my dad's original set. It is now a museum piece - I prefer to use modern transformers! If you want to risk an old 1960s transformer, you can find them on eBay, but it would be a good idea to have it thoroughly checked out by a competent electrician before using. For a modern solution, probably the easiest plug & play option is to fit a new all-in-one powerbase with a new power supply and controllers. Your set 31 uses the Scalextric 'Classic' track system wihich is different to the current 'Sport' track. You have two options - either buy a modern analogue powerbase (for example, C8217, C8530, C8545 etc) with a 'Sport' to 'Classic' adapter (C8222) at each end, or find a 'Classic' powerbase (eg C8014) from a 1990s set. There are plenty on eBay. Hope that helps. Link to comment Share on other sites More sharing options...
Eddieand0 Posted April 29, 2018 Author Share Posted April 29, 2018 Thanks Woodcote will give it a try! Link to comment Share on other sites More sharing options...
