BODS3 Posted May 21, 2018 Share Posted May 21, 2018 Updated to 1.68 and now unable to operate locos from speed sliders. Have found by trial and error that if I move slider to required speed nothing happens but if I operate the direction button forward or reverse locos go to that speed.Also I can only select up 2 locos to show large control panels on screen I thought you could show more!ps speed sliders work on large panels when selected.Have re loaded old version for now and everything o/k.any ideas? Link to comment Share on other sites More sharing options...
Chrissaf Posted May 21, 2018 Share Posted May 21, 2018 Also I can only select up 2 locos to show large control panels on screen I thought you could show more!.No....there has never been more than two large controllers supported on screen at the same time, and that only when using RM ProPack edition. The RM Standard edition only supports a single large controller..Have re loaded old version for now and everything o/k..What version is the old RM version?.Also what version of Windows? Link to comment Share on other sites More sharing options...
Britannia Builder Posted May 21, 2018 Share Posted May 21, 2018 The problem with the speed slider was introduced in 1.67 - if you don't have 'send real-time speed data' enabled in the system settings, the slider doesn't work. See https://www.hornby.com/uk-en/forum/post/view/topic_id/21062/?p=6 Regards, John Link to comment Share on other sites More sharing options...
BODS3 Posted May 22, 2018 Author Share Posted May 22, 2018 Also I can only select up 2 locos to show large control panels on screen I thought you could show more!.No....there has never been more than two large controllers supported on screen at the same time, and that only when using RM ProPack edition. The RM Standard edition only supports a single large controller..Have re loaded old version for now and everything o/k..What version is the old RM version?.Also what version of Windows?Ver 1.64 Working okver 1.68 speed slider problemwindows vista home premium 2007 service pack 2 Link to comment Share on other sites More sharing options...
BODS3 Posted May 22, 2018 Author Share Posted May 22, 2018 The problem with the speed slider was introduced in 1.67 - if you don't have 'send real-time speed data' enabled in the system settings, the slider doesn't work. See https://www.hornby.com/uk-en/forum/post/view/topic_id/21062/?p=6 Regards, John John enabling or disenabling real time speed data made no difference Link to comment Share on other sites More sharing options...
Britannia Builder Posted May 22, 2018 Share Posted May 22, 2018 The problem with the speed slider was introduced in 1.67 - if you don't have 'send real-time speed data' enabled in the system settings, the slider doesn't work. See https://www.hornby.com/uk-en/forum/post/view/topic_id/21062/?p=6 Regards, John John enabling or disenabling real time speed data made no difference Note that you have to restart Railmaster after turning on the real-time speed data option for it to take effect (another bug!) Regards, John Link to comment Share on other sites More sharing options...
BODS3 Posted May 23, 2018 Author Share Posted May 23, 2018 The problem with the speed slider was introduced in 1.67 - if you don't have 'send real-time speed data' enabled in the system settings, the slider doesn't work. See https://www.hornby.com/uk-en/forum/post/view/topic_id/21062/?p=6 Regards, John John enabling or disenabling real time speed data made no difference Note that you have to restart Railmaster after turning on the real-time speed data option for it to take effect (another bug!) Regards, JohnThis worked ok thanks John Link to comment Share on other sites More sharing options...
