Royboy43 Posted June 22, 2018 Share Posted June 22, 2018 Hi Does anyone have any experience with converting thr above engine to DCC.many thanks Roy Link to comment Share on other sites More sharing options...
Chrissaf Posted June 22, 2018 Share Posted June 22, 2018 https://www.hornby.com/uk-en/forum/britannia-dcc-conversion/#post-233647 Link to comment Share on other sites More sharing options...
The son of Triangman Posted June 23, 2018 Share Posted June 23, 2018 Easy conversion to do, but beware of the cast pin under the left contact on this old loco or you will have a short between the negative feed and a motor control wire on the decoder. Link to comment Share on other sites More sharing options...
Royboy43 Posted June 23, 2018 Author Share Posted June 23, 2018 Thanks for advice I now see the pin that you refer to.I will now have a go.Cheers Roy Link to comment Share on other sites More sharing options...
The son of Triangman Posted June 23, 2018 Share Posted June 23, 2018 Bend the brush wire tag away from it and insulate the brush wire tag with heatshrink Link to comment Share on other sites More sharing options...
2e0dtoeric Posted June 23, 2018 Share Posted June 23, 2018 Can it be ground off with a dremel? Link to comment Share on other sites More sharing options...
