des480 Posted June 28, 2018 Share Posted June 28, 2018 When I had my old Duplo layout over50 years ago I used to pair points linking between tracks to ensure that they were both either straight on or allowing to change track. Can I do the same with a Hornby r8247 linking two points to change together by simply wiring them to the same port. Link to comment Share on other sites More sharing options...
Chrissaf Posted June 28, 2018 Share Posted June 28, 2018 Yes. Link to comment Share on other sites More sharing options...
81F Posted July 7, 2018 Share Posted July 7, 2018 I would say it depends on how much current the motors draws or how strong the motor is or if the point is particularly stiff. Currently I have four pairs of motors wired together, Two cross-overs as you describe and two single slips mostly powered by PECO motors. 3 of them worked perfectly but the fourth only switched one. I've just replaced the unreliable motor but have yet to nail it in position but a temporary lashup seems to look prommising Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 7, 2018 Share Posted July 7, 2018 About the only motor I remember from many years on here which won’t work in pairs reliably is Seep. Link to comment Share on other sites More sharing options...
37lover Posted July 7, 2018 Share Posted July 7, 2018 Fishmanoz,I have not had any trouble with my eight pairs of Seep point motors. Link to comment Share on other sites More sharing options...
