Spireblade Posted August 11, 2018 Share Posted August 11, 2018 A minor problem, but having just rebuilt my railway and giving it a test run with 2 new locos, occasionally they are cutting out and restarting TOGETHER. I am running RM through an Elite, 2 locos and 8 Train Tech LED signals. Track and signals all connected to a buss wire. Am I drawing too much current? The decoders are Gaugemaster DCC26 in each loco if that helps. Cheers Link to comment Share on other sites More sharing options...
Chrissaf Posted August 11, 2018 Share Posted August 11, 2018 Track and signals all connected to a BUS wire..I would be checking all the joints on your DCC BUS wiring. Both locos cutting out together indicates a general track power problem rather than a decoder one. It could be an intermittent short but if it was, one would expect to be able to hear it as a buzzing noise. If it was a more long lived short, then the Elite would trip. Chances are that as the locos auto restart and the Elite doesn't trip, the issue is more likely to be a break in the power rather than a short..Am I drawing too much current?.Only two locos and eight signals is unlikely to draw anything remotely close to 4 amps (Elite power supply), so I doubt that is the problem. Link to comment Share on other sites More sharing options...
Spireblade Posted August 12, 2018 Author Share Posted August 12, 2018 Thanks Chris, I'll get back under the board and recheck all the connections. Link to comment Share on other sites More sharing options...
