grumpy old man Posted January 23, 2012 Share Posted January 23, 2012 Can anybody tell me what the 4 different positioned Y points are and how do they fit in and attached to the red& green markers I tried them on a points test design but can`t get any blue pointers to work with them I had a assigned a spare port number but no joy.I have found one solution to another problem I had, it was when I reduced the control screen to 75% I could not view the point port numbers but could view the titles of the track & sidings, Hornby CS said it only showed on 100% screen to overcome this when in design clik on label & type in the point port number with the prefix P this should overcome the problem.Any feedback would be greatly appreciated Don R Link to comment Share on other sites More sharing options...
David55 Posted January 23, 2012 Share Posted January 23, 2012 when you have placed the points into position, pick up a red and drop this on the vertical line opposite the y end. This should be to open the points.Then pick up the green and drop this on the same vertical line on the other side of the point also opposite the y end. This should then close it.Hopes this helps Link to comment Share on other sites More sharing options...
David55 Posted January 23, 2012 Share Posted January 23, 2012 Also should have said above and below but not on the points. Link to comment Share on other sites More sharing options...
