trainzcal2001 Posted January 23, 2012 Share Posted January 23, 2012 Do you need ALL the decoders to be the same to work on one dcc system Link to comment Share on other sites More sharing options...
ChrisWV10 Posted January 23, 2012 Share Posted January 23, 2012 trainzcal2001 said:Do you need ALL the decoders to be the same to work on one dcc systemNope. Any suitable NMRA compliant decoder (all of them) can be used with any NMRA complliant DCC control system (nearly all of them) When I say suitable, I mean 6 or 8 or 21 pin according to the socket fitted, in the case of DCC ready or whatever takes your fancy/suits your budget if you're soldering one in. The only non compliant widely available controller is our beloved Select... and that will still work with many. Best thing to ask if you have a particular combination in mind with the Select.C. :) Link to comment Share on other sites More sharing options...
DW Posted January 23, 2012 Share Posted January 23, 2012 [reply]trainzcal2001 said:Do you need ALL the decoders to be the same to work on one dcc systeMIn short - NoJust make sure all your equipment and decoders are NMRA certified.Cheers, Link to comment Share on other sites More sharing options...
