6667s Posted November 12, 2018 Share Posted November 12, 2018 Just bought an railtrack class 156 with sound, the function buttons do not have all the sounds in the drop down list, can i wright them in to the program, and how? Link to comment Share on other sites More sharing options...
Chrissaf Posted November 12, 2018 Share Posted November 12, 2018 .....can I write them in to the program, and how?.YesIn the 'Locomotive Set Up' Screen. Just edit the function button label directly in the text box field that displays it. Note that if a function is supposed to stay latched on, then the text on/off MUST be written on the function button label. There is a limitation on the number of characters you can write, so use short names and abbreviations as appropriate..The 'check boxes' on the right hand side select the six (only six can be selected) functions that will appear on the small throttle. All functions will appear on the large throttle. The function buttons on the large throttle are scrollable to see those functions above the ones that are initially visible. Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 13, 2018 Share Posted November 13, 2018 Have you checked if the R number for your loco, including T at the end of the number (most important), is in RM’s list of locos, after you’ve downloaded and installed the very latest version of RM from the link at the top of the forum (do it again even if you did it only yesterday)? Finding it saves you doing the setup manually as Chris has described. Link to comment Share on other sites More sharing options...
Chrissaf Posted November 13, 2018 Share Posted November 13, 2018 Fishy,I don't think the OP's model is a Hornby one. I think it is a typo in the post and the loco is made by Realtrack (not Railtrack). If my suspicion is correct, then it won't be in the RM database..See this web page for their Class 156 locos.https://www.realtrackmodels.co.uk/ Link to comment Share on other sites More sharing options...
