e.linker99 Posted January 2, 2019 Share Posted January 2, 2019 I've acquired a Hornby R1076 Pendolino DCC-fitted set (unfortunately, NOT the "DCC-Ready" loco). I want to replace the Hornby-fitted decoder in the driving loco with a sound chip, but I'm hesitating... The Hornby-fitted decoder (forum research indicates it might be an old-style R8215, no coloured dot) employs a 7-pin socket which plugs in to a 7-pin PCB on the loco. The connections on the loco's PCB are numbered J2 through J8, with the following colour of wires running to the decoder: PCB Decoder Wire J2 BLACK J3 GREY J4 YELLOW J5 WHITE J6 BLUE J7 ORANGE J8 RED So, if those decoder wire connections are to NRMA standards, I believe I should plumb in an 8-bit socket to the loco's PCB like this: PCB Decoder Wire NEM 652 socket J2 BLACK Pin 4 J3 GREY Pin 5 J4 YELLOW Pin 2 J5 WHITE Pin 6 J6 BLUE Pin 7 J7 ORANGE Pin 1 J8 RED Pin 8 Has anybody tried connecting an 8-pin decoder to the Pendolino 7-pin PCB (via an 8-pin trailing socket)? Your advice, criticism, and even pithy comments appreciated, before I cut off that Hornby decoder from its 7-pin plug and recycle it [grins]... Thanks! Colin Link to comment Share on other sites More sharing options...
Chrissaf Posted January 2, 2019 Share Posted January 2, 2019 Those pin-outs look correct. They match with this drawing that you might find useful as part of your modification../media/tinymce_upload/3c9cefd175aa3c8bc7fce9fece35e457.jpg. Link to comment Share on other sites More sharing options...
e.linker99 Posted January 2, 2019 Author Share Posted January 2, 2019 Thanks, Chrissaf, I'm encouraged ... about to wield the knife and the soldering iron NOW!CheersColin Link to comment Share on other sites More sharing options...
