GrahamWass Posted February 1, 2012 Share Posted February 1, 2012 As the title sugests I am wanting to replace the origional early hornby decoder with a sound decoder but looking at the motor it has what apoears to be resistors or the like wired into it . they are covered in a red sleeve so dificult to see what they are. First what are they Second should I remove them before fitting none hornby decoder. Third will I get a slapped wrist for not fitting Hornby decoder. But I want soundThanks Graham Link to comment Share on other sites More sharing options...
peterz Posted February 1, 2012 Share Posted February 1, 2012 GrahamWass said:As the title sugests I am wanting to replace the origional early hornby decoder with a sound decoder but looking at the motor it has what apoears to be resistors or the like wired into it . they are covered in a red sleeve so dificult to see what they are. First what are they Second should I remove them before fitting none hornby decoder. Third will I get a slapped wrist for not fitting Hornby decoder. But I want soundThanks Graham Link to comment Share on other sites More sharing options...
peterz Posted February 1, 2012 Share Posted February 1, 2012 GrahamWass said:As the title sugests I am wanting to replace the origional early hornby decoder with a sound decoder but looking at the motor it has what apoears to be resistors or the like wired into it . they are covered in a red sleeve so dificult to see what they are. First what are they Second should I remove them before fitting none hornby decoder. Third will I get a slapped wrist for not fitting Hornby decoder. But I want soundThanks GrahamPresumably the fitted decoder is in a socket, in which case it depends whether its 21 pin or 8 pin.In either case the sound decoder will simply be a direct replacement with no other alterations neccessary.if its 8 pin there will be 2 extra wires for the speakerIn the case of 21 pin there will be no extra wires, but in modern locos the pcb usally has terminals for speaker.hope this helps. Link to comment Share on other sites More sharing options...
GrahamWass Posted February 1, 2012 Author Share Posted February 1, 2012 peterz said:Presumably the fitted decoder is in a socket, in which case it depends whether its 21 pin or 8 pin.In either case the sound decoder will simply be a direct replacement with no other alterations neccessary.if its 8 pin there will be 2 extra wires for the speakerIn the case of 21 pin there will be no extra wires, but in modern locos the pcb usally has terminals for speaker.hope this helps.Yes Many thanksGraham Link to comment Share on other sites More sharing options...
GrahamWass Posted February 1, 2012 Author Share Posted February 1, 2012 Yes Many thanks Graham Link to comment Share on other sites More sharing options...
