DO2RFC Posted January 19, 2019 Share Posted January 19, 2019 Good eveningI would like to know if it is possible to run standard DC loco with elink and railmaster.I have a digitrax Zyphire too and at this divice I can change to adress 00 and run a analogloco on my track.Have the railmaster and elink such a aditional adress too.? Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 19, 2019 Share Posted January 19, 2019 It will work for a short time, but you are EXTREMELY strongly advised not to do it.We know the book says you can, but the motor is 'seeing' pulsed 16V, even with throttle zero set. So it is minutely rocking from side to side, not rotating, and the poor little coil is getting hotter and hotter until it melts.I'm not being dramatic here, it is what happens!Instead of the speed control knob increasing or decreasing the volts being fed to the motor, in the smooth analogue form it is designed for, it is getting varied length pulses of alternating 16v a/c. By changing the length of the off/on pulses, this varies the speed of the motor, but you probably heard it buzzing like a bee in a jam-jar.Up-to-date DCC controller manuals are being written that says do not, and the function zero setting is being removed from controllers, as they get updated. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 19, 2019 Share Posted January 19, 2019 RailMaster can not set or use Address Zero. There is no Analogue loco support in RM..As Eric says, it is not recomended anyway, even if your controller manual says it is supported. Just because it can be done on some controllers, does not necessarily mean that it is a good idea..Google "Mark Gurries" and search his site for "DC Loco" Link to comment Share on other sites More sharing options...
Chrissaf Posted January 19, 2019 Share Posted January 19, 2019 Here is a direct link.https://sites.google.com/site/markgurries/home/technical-discussions/dc-loco-on-dcc/dc-locomotive-damage-risk Link to comment Share on other sites More sharing options...
DO2RFC Posted January 23, 2019 Author Share Posted January 23, 2019 Thanks to all guys for help.Best regards Ralph Link to comment Share on other sites More sharing options...
