Deviousweegee Posted March 2, 2019 Share Posted March 2, 2019 Hello I'm very new here and am just looking for some help I've purchased some laisdcc 21 pin decoders to run in my locos as they're much cheaper, but my Hornby select (1.5 firmware) doesn't appear to be to work with them. It seems like the chip correctly registers the loco address (set to 03) but when I try to make the loco move or operate it's functions it doesn't work.Does anybody know why or have a solution for this? Many thanks Link to comment Share on other sites More sharing options...
DEREK123 Posted March 3, 2019 Share Posted March 3, 2019 Hi Deviousweegee Like yourself I am experimenting with these LAISDCC decoders although I use the 8 pin variaty... They are proving pretty good considering they are cheap but they have specific differences in CV control which may be giving you a problem on the SELECT because you may have to reset the decoder which is CV 8 = 4 !! not the Hornby and others standard which I think I am right in thinking is CV 8 = 8Check their website ........ there is a LAISDCC CVlist .Will a SELECT reset a decoder CV ? it may only reset to 8. !!! ..... I don't know .... someone I am sure will come along with their SELECT knowledge .Good Luck.Derek Link to comment Share on other sites More sharing options...
jane1707819582 Posted March 3, 2019 Share Posted March 3, 2019 the select will not reset a decoder,weegee try cleaning your track and press gently on the loco whilst programming , how many times does the led flash ?double check that the decoder is in it's socket correctly the select does not "register a decoder" ,it goes to 03 by default Link to comment Share on other sites More sharing options...
96RAF Posted March 3, 2019 Share Posted March 3, 2019 When v1.6 firmware is made available the Select will be able to change all CVs up to 255. Hence a decoder reset will be possible by writing the required value to CV8. Hornby stated at the recent Scottish Show that they were gearing up for a v1.6 update campaign (at some cost unless you have just had v1.5 installed I guess). Link to comment Share on other sites More sharing options...
Deviousweegee Posted March 3, 2019 Author Share Posted March 3, 2019 the select will not reset a decoder,weegee try cleaning your track and press gently on the loco whilst programming , how many times does the led flash ?double check that the decoder is in it's socket correctly the select does not "register a decoder" ,it goes to 03 by default Thanks for the advice I'll give this a try. It flashes 3-4 times Link to comment Share on other sites More sharing options...
DEREK123 Posted March 3, 2019 Share Posted March 3, 2019 Hi againHere is the link for the Laisdccc CV list.. https://laisdcc.com/cvlist.pdfBy the way welcome to the site and hobby.Derek Let us all know how you get on. Link to comment Share on other sites More sharing options...
Chrissaf Posted March 3, 2019 Share Posted March 3, 2019 Also, for best results, disconnect the Select completely from the main layout track and connect it directly to a short track piece that you dedicate for programming work. This is more efficient than removing all your rolling stock from the main layout before undertaking a programming task and reduces the risk of induced interference on the main track from affecting the programming signal. Link to comment Share on other sites More sharing options...
Deviousweegee Posted March 4, 2019 Author Share Posted March 4, 2019 Thanks for all of your help but nothing appears to be working, I'm wondering if I should buy railmaster to reprogram the CVs? Is it worth it or is there anything else I can try?Many thanks Link to comment Share on other sites More sharing options...
Chrissaf Posted March 4, 2019 Share Posted March 4, 2019 .....is there anything else I can try?.A cheaper option than RailMaster / eLink, would be to buy a 'SPROG II v3' at about £45 and download (free) JMRI DecoderPro. This combination will program and configure just about every DCC decoder known to man. The one negative caveat is that DecoderPro software is not for the faint hearted....it potentially can be a steep learning curve if one is not used to using sophisticated DCC software products. I have a 'SPROG II v3' with JMRI as well as RailMaster with Elite. Just be aware that the 'SPROG II v3' is designed primarily as a DCC programming interface. It can be switched into 'operations mode', but this is meant to be just for testing your newly implemented DCC configuration. It is not meant to be used as a full blown layout controller. But it could potentially be used for that if its output was fed through a DCC Booster..Note that later this year a Hornby interface will be launched (Select-a-Link) that will allow the Select to be controlled by RailMaster. This may or may not offer you a solution to your issue. I suppose it depends whether your current issue is an issue with your Select hardware itself or not. Link to comment Share on other sites More sharing options...
DEREK123 Posted March 4, 2019 Share Posted March 4, 2019 Just an idea but do you have a friendly local model shop with a DCC layout / and / or a good controller like an Elite ? Maybe they could / would program and test the decoder / loco for you at low cost ?Derek Link to comment Share on other sites More sharing options...
Deviousweegee Posted March 4, 2019 Author Share Posted March 4, 2019 Just an idea but do you have a friendly local model shop with a DCC layout / and / or a good controller like an Elite ? Maybe they could / would program and test the decoder / loco for you at low cost ?DerekThanks I'll make a few calls and see if they're interested Link to comment Share on other sites More sharing options...
96RAF Posted March 4, 2019 Share Posted March 4, 2019 Seeing as you are havng problems with TTS decoders as well (separate thread) then I suggest yuo reset the Select controller using the method shown in the v1.5 manual downloadable from the main Hornby site downloads area. Often a controller reset (as opposed to a decoder reset which your Select cannot do yet) will cure all manner of ills. Link to comment Share on other sites More sharing options...
Deviousweegee Posted March 4, 2019 Author Share Posted March 4, 2019 Seeing as you are havng problems with TTS decoders as well (separate thread) then I suggest yuo reset the Select controller using the method shown in the v1.5 manual downloadable from the main Hornby site downloads area. Often a controller reset (as opposed to a decoder reset which your Select cannot do yet) will cure all manner of ills.Thanks for the advice, I tried this and it just gave the same results unfortunately Link to comment Share on other sites More sharing options...
Chrissaf Posted March 4, 2019 Share Posted March 4, 2019 TIP: When you write a reply, it would be appreciated if you didn't keep using the 'White Arrow in Blue Box' button. This is not a 'Reply to this post button. It is best to write any reply you want to make in the 'Reply Text Box' at the very bottom of the page and click the Green 'Reply' button. Particularly relevant when you are replying to the post directly above yours..If you just want to bring your reply to the attention of......then just start your reply with "@username" where username is the name of the member that you want to bring to the attention of your reply..It is not so much of a problem when you are re-quoting relatively short replies, but if you start re-quoting long ones it can be very off-putting having to re-read the previous replies unnecessarily..Your replies are not too much of an issue, as at least you do write your text in clear space as black text on white background. But many newbies write their reply inside the yellow re-quote highlight box, then it becomes a devil of a job to separate out the new text from the re-quote. Link to comment Share on other sites More sharing options...
RichC 123 Posted March 14, 2019 Share Posted March 14, 2019 Just to update the people on this thread. I believe I supplied these chips, they have been returned to myself and we have refunded the customer. We have had all the chips on test on a ESU test board and and in a Bachmann 66 and the chips work perfectly. Link to comment Share on other sites More sharing options...
96RAF Posted March 14, 2019 Share Posted March 14, 2019 ...We have had all the chips on test on a ESU test board and and in a Bachmann 66 and the chips work perfectly. Using which controller(s)...Folk have reported on other forums about problems getting Liaisdcc decoders to work with some controllers, even some with NMRA warrants. As you are obviously a distributor for these decoders would you know if the latest versions of these decoders are Liaisdcc own design or copies of other makes as the originals were found to be copies by TCS. Please be aware that forum rules prevent you from actively promoting the product but not from defending it. Link to comment Share on other sites More sharing options...
RichC 123 Posted March 16, 2019 Share Posted March 16, 2019 Tested with both a NCE powercab and a Hornby Select we suspect it was a loco issue. Link to comment Share on other sites More sharing options...
96RAF Posted March 16, 2019 Share Posted March 16, 2019 Thanks RichDevious - if you download the RM demo and look in the force deocder drop down list in CV7 you will see if your Liaisdcc decoder is supported. If so it should work with Select as well. As Rich says it may be a loco problem, can you swap it into another loco you know is good. Link to comment Share on other sites More sharing options...
Deviousweegee Posted April 16, 2019 Author Share Posted April 16, 2019 Thanks RichDevious - if you download the RM demo and look in the force deocder drop down list in CV7 you will see if your Liaisdcc decoder is supported. If so it should work with Select as well. As Rich says it may be a loco problem, can you swap it into another loco you know is good.Hi sorry for late reply, been busy How do I connect my select to RM and I also tried the chip in a Bachmann 70 with same result. Thanks Link to comment Share on other sites More sharing options...
Chrissaf Posted April 16, 2019 Share Posted April 16, 2019 I don't particularly want to put words in Rob's mouth, but I think you might have slightly mistook what he was saying. I think he was referring to a metaphorical download of RM. In other words, if you were theoretically to download an evaluation copy of RM and open the decoder list. You would find the Laisdcc chip listed. Therefore it is logical to assume that Hornby support for the Laisdcc chip extends across the Hornby controller range, including the Select. He was not I believe suggesting that you actually downloaded RM and tried to connect it to your Select..RM support for the Select is however due for release later this year via the 'Select-a-link" cable and this release is timed to coincide with Select firmware release version 1.6..TIP: When you write a reply, it would be appreciated if you didn't keep using the 'White Arrow in Blue Box' button. This is not a 'Reply to this post button. It is best to write any reply you want to make in the 'Reply Text Box' at the very bottom of the page and click the Green 'Reply' button. Particularly relevant when you are replying to the post directly above yours.. Link to comment Share on other sites More sharing options...
ColinB Posted April 21, 2019 Share Posted April 21, 2019 I fitted one of these to my Bachman EMU and found it worked perfectly. The only issue I had was initially installing it, but that was more to do with the 21 pin arrangement, I am more used to 8. I am using an Elite. I did have issues with fitting one in a Hornby Schools, where I didn't think it had sufficient drive to power the motor, but I think that it was more an issue with the loco. Link to comment Share on other sites More sharing options...
DEROB Posted March 30, 2020 Share Posted March 30, 2020 I use Laisdcc 6-pin, 8-pin, 21-pin and Next18 decoders with Prodigy Advance2 and have no problems at all. Just got to know you way around the Laisdcc CV Table and no problems. Their user instructions which are downloadable are not in the best English though. They remind me of the old joke when the Chinese waiter asked the customer if he liked his steak and the customer replied, "It was rubbery", to which the Chinese waiter replied, "I'm grad ru riked it."Back EMF CVs are different to a lot of mainstream but you can get better info from TCS as Laisdcc decoders are basically a Hong-Kong 'knock-off' of TCS decoders. TCS were, or maybe still are, pursuing litigation against Laisdcc. The Select is not the best of DCC controllers as it is very basic and doesn't let you do much with CVs. Link to comment Share on other sites More sharing options...
96RAF Posted March 30, 2020 Share Posted March 30, 2020 So what is your question or are you just giving us the benefit of your experience. Your posting history doesn’t ask many questions either but you do seem to have ‘issues‘ with a lot of products. By the way if you get your Select updated to v1.6 it will be able to change all CVs for any supported value including your Liaisdcc ‘knock-offs’ - your words. Link to comment Share on other sites More sharing options...
Howbi Posted March 30, 2020 Share Posted March 30, 2020 The Select is not the best of DCC controllers as it is very basic and doesn't let you do much with CVs.Unless you have the Select upgraded by Hornby at a cost of £15. The latest Firmware v1.6 (v2.0 on a new Select) enables access to all the major CVs notably CV29. This upgrade makes the Select a very capable DCC controller........HB Link to comment Share on other sites More sharing options...
ColinB Posted March 31, 2020 Share Posted March 31, 2020 One of the things I will add to this post, is from my experience (may be different to other peoples), the decoder doesn't work that well with a "dodgy" track signal. When I have fitted the 8 pin variety to locos without decent "pickups" they sometimes, when they lose the signal, on occasions made the loco go in the opposite direction to that programmed. I tend to use the 21 pin versions on Bachmann Diesels and EMUs because these have decent pickups and so far have had no issues with them going backwards. Another couple of uses for them, is as function decoders as they are so cheap or something you use to test out the wiring of the DCC socket, as in my case where you have converted an old loco. It is much better to damage a £10 decoder, than a £20+ one. I have used the 8 pin types in DMUs where you need one for the opposite end to switch on the lights, again why waste an expensive one, when you are not going to use any of the motor drive facilities. In my case I don't really mess with CV values, all I want is a decoder to drive the loco, so for me as long as they don't go backwards they are perfect in the 21 pin variety. Link to comment Share on other sites More sharing options...
