Ullswater Posted March 5, 2019 Share Posted March 5, 2019 Hi thereI have the R070 turntable that I have converted to DCC using the Horby method. All works fine except for two things:1. The turntable rotates the opposite way to that which I expect. Can I resolve this within Railmaster?2. I'm using the speech recognition in Railmaster to control the turntable. The instructions, on page 63, say this: You can also control turntables by saying “Turntable twenty one” (or the number of your turntable) followed by “Clockwise two” to move forward two roads or “Anticlockwise four” to move anticlockwise through four roads” - but I cannot get this to work. I can only get use the commands "Turntable Right", "Turntable Left", "Turntable Clockwise" and "Turntable Anticlockwise". Any attempt to add "Turntable Eight" (the Loco ID of my turntable is 008) is ignored, and adding a number of roads to turn through is not understood. Does anyone else have a similar experience?Thanks very much in advance! Link to comment Share on other sites More sharing options...
2e0dtoeric Posted March 5, 2019 Share Posted March 5, 2019 I've not used Railmaster, but the simple way of correcting a wrong direction rotation is by swapping the two motor feed wires over. Link to comment Share on other sites More sharing options...
Ullswater Posted March 5, 2019 Author Share Posted March 5, 2019 Thanks Eric. I'm using a decoder to drive the motor so wondering if I can simply swap over the decoder wires that go to the power? Link to comment Share on other sites More sharing options...
2e0dtoeric Posted March 5, 2019 Share Posted March 5, 2019 No! You have to swap over the output of the decoder, not the input.Very crudely, the input to the decoder is a/c so swapping the wires there will achieve nothing, as the decoder converts the volts to dc.You have to change the wires over between the output of the decoder, and the motor, to get it to turn the other way! Link to comment Share on other sites More sharing options...
Rog RJ Posted March 5, 2019 Share Posted March 5, 2019 CV 29 can be used to reverse the motor direction. Probably easier and safer than reversing the motor connections in the confined space of the turntable. Link to comment Share on other sites More sharing options...
Ullswater Posted March 5, 2019 Author Share Posted March 5, 2019 Thanks. I think I knew that really. I appreciate the reply, Eric. Link to comment Share on other sites More sharing options...
Ullswater Posted March 5, 2019 Author Share Posted March 5, 2019 Brilliant. Thanks Rog. Will try that now. Link to comment Share on other sites More sharing options...
Ullswater Posted March 5, 2019 Author Share Posted March 5, 2019 It worked - thanks very much indeed for your help gents. Link to comment Share on other sites More sharing options...
