The Bowl Posted March 16, 2019 Share Posted March 16, 2019 Hi folks, first post though have been reading for a while. Recently setup my first DCC set. Would I be right in saying that I can’t be using older track on newer DCC due to the different voltage? I have a heap of older track from my previous DC set that hasn’t been used recently and just wondering if it can be used to extend the layout or not! I may look tomrun the DC round the outside for show. Thanks in advance. Link to comment Share on other sites More sharing options...
Rog RJ Posted March 16, 2019 Share Posted March 16, 2019 You can use any track. Link to comment Share on other sites More sharing options...
Chrissaf Posted March 16, 2019 Share Posted March 16, 2019 Track is track it makes no difference, the main thing to be aware of is that the DC track power connectors have suppression capacitors in them. These should be removed before using them on a DCC layout. Points also need to be made DCC friendly by fitting R8232 DCC point clips..TIP,Please do not use the blue button to reply. This is not a reply to this post button. Please scroll down to the bottom of the page, write your reply in the reply text box and click the green reply button. Thank you. Link to comment Share on other sites More sharing options...
The Bowl Posted March 16, 2019 Author Share Posted March 16, 2019 Thanks folks, my son and I were debating this and he was right. I won’t be telling him that though. Like some of the track, I’m a bit rusty with all this but excited to be getting back into with the lad. Link to comment Share on other sites More sharing options...
Chrissaf Posted March 17, 2019 Share Posted March 17, 2019 DCC is so much less forgiving than DC when using corroded track. If your track is showing signs of rust, then it is steel and not Nickle Silver. Track that is rusty will give you nothing but trouble, particulary with DCC. Bin it, it is a false economy to try and clean up rusty steel track. It will start to rust again very quickly. Link to comment Share on other sites More sharing options...
Rog RJ Posted March 17, 2019 Share Posted March 17, 2019 Rusty track isn't good for smooth running. DCC locos are likely to work much worse than analogue models on rusty track. Link to comment Share on other sites More sharing options...
The Bowl Posted March 18, 2019 Author Share Posted March 18, 2019 Thanks folks, no intention of using the rusty track - was more to describe my novice status than anything else! Link to comment Share on other sites More sharing options...
