Devyn Gamble Posted July 3, 2019 Share Posted July 3, 2019 Hello,I have the select controller and I am trying to program a locomotive, I do the normal procedure and the red light flashes 2 times and then the locomotive jumps forward and then won’t move. Has anyone else had the same problem? Link to comment Share on other sites More sharing options...
Chrissaf Posted July 3, 2019 Share Posted July 3, 2019 Not enough information provided, more detail is required..What is the firmware revision of the Select? (shows as a two digit number between 11 and 16 that briefly appears on screen during the power on self test.).What decoder......brand and model?.Are you using a separate dedicated track piece for 'programming' that is temporarily attached to the Select 'Track Output'?.If not, and you are using the main layout for programming your loco, are you removing ALL other devices that are equipped with a decoder from the layout. This includes any 'Accessory Decoders' that might be installed for point operation..What DCC address are you trying to configure....is it in the range 01 to 59?(Loco DCC Addresses outside this restricted range will not work on a Select).TIP: As this is your very first post, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button. Link to comment Share on other sites More sharing options...
