Chrissaf Posted July 26, 2019 Share Posted July 26, 2019 You could try Hornby for repairs but it may be uneconomical. If you are capable of diagnostics and repair to circuit board level then have a look here.http://www.halton96th.org.uk/page14.htmlF2 may be the culprit causing cyclic shutdown. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 26, 2019 Share Posted July 26, 2019 I purchased a railmaster and eLink system some time ago but when I came to use it it seemed to run for a short time shop comunicating. I have purchased a second one this works with no problems. I want to get the first one sorted out.It appears that the eLink unit when plugged in works for about 10 to 15 minutes then cuts out discount it for at an hour and it works again for 10 to 15 minutesI think the must be a dry joint or some think like that. I have has it for will overca year so it will be out of garanty Does any one have any ideas as what I should to get it repaired Link to comment Share on other sites More sharing options...
