Stu60009 Posted August 1, 2019 Share Posted August 1, 2019 Hi everyone I recently Purchased an r3503 with R8106 TTS SOUND DECODER for the meantime I need to run it on my analogue layout. Would I need a blanking plug or will it just run on the dc or isit a "simple case" of unplugging the chip. any help would be greatly appreciated Link to comment Share on other sites More sharing options...
Johnde Posted August 1, 2019 Share Posted August 1, 2019 As long as your not using an electronic track cleaner or similiar device a TTS fitted loco should run on a DC powered track. Dont expect any sounds from it..If your not sure then unplug the TTS decoder and fit a blanking plug in place, having no plug in place your loco will not run.If in doubt take the decoder out and you must then fit a blanking plug into the socket.Hope this helps. Link to comment Share on other sites More sharing options...
ff2nd Posted August 2, 2019 Share Posted August 2, 2019 R3503TTS does NOT have DC running turned on in the decoder. You will need to contact Hornby Customer Services, and ask for the right blanking plate for your loco. (There are several types now, with varying diode arrangements.) Link to comment Share on other sites More sharing options...
