Chrissaf Posted August 3, 2019 Share Posted August 3, 2019 1. I've ran 5 locos with one having sound using a 1 Amp transformer. I don't know if it would power 5 sound locos.2. Better to wire directly to the track at multiple locations. Link to comment Share on other sites More sharing options...
Tonyob Posted August 3, 2019 Share Posted August 3, 2019 Thank you Norman. 1 will have to suck and see if the transformer is up to the job. I have gome a bit overboard on connections and soldered to ever piece of track onto a main ring loop. Just waiting for Railmaster/ E - link to turn up and then the fun will begin from what I have read on the forum with some of the problems reported.Let’s hope mine is straight forward.Thanks againTony Link to comment Share on other sites More sharing options...
Chrissaf Posted August 9, 2019 Share Posted August 9, 2019 I am biting the bullet and about to order up rail master/ elink. I note the transformer is only 1amp. Is this sufficient to run 5 loco’s at once with sound.1. Will I need to order up a bigger transformer.2. Do I need to use the Hornby digital track section connection or can I hard wire under the board.iI will fully read all the advise on how to set up etc when I placed my order for the right kit.thankyou. Link to comment Share on other sites More sharing options...
