jtc Posted October 7, 2019 Share Posted October 7, 2019 HiI am struggling with theR8247 decoder with my elite. Hav'nt connected points before Link to comment Share on other sites More sharing options...
Chrissaf Posted October 7, 2019 Share Posted October 7, 2019 jtc,Welcome with your first post..It would have been a little bit more helpful if you had described what aspect of using your R8247 decoder with the Elite you are struggling with..For example, your difficulty could be with any aspect of the following....either:.Configuring the R8247 operating firmware.....setting DCC addresses etc. Particularly if using multiple R8247s.Wiring the R8247 to your point motors. Connecting the R8247 decoders to your Elite.How to use your Elite to select the point addresses and operate the points.The point just doesn't operate either correctly or reliably.Or something else altogether..Now if you could give us a clue as to what you are struggling with, then we can give you targeted advice..Please do include in your next reply:.What track you are using.....is it Hornby?What point motors you are using......brand and model number?How many R8247 decoders have you got?What aspect of using a R8247, exactly you are struggling with?.In the meantime, here are a selection of existing threads devoted to different aspects of the R8247 decoder. One of these might answer your query if we knew what it was..Programming a R8247 using Elitehttps://www.hornby.com/uk-en/forum/programming-a-2nd-r8247-to-elite-controler/?p=1/.using Elite (version 2, doesn’t include the reset task, just configuration)https://www.hornby.com/uk-en/forum/hornby-accessory-decoder-26895/?p=1.Wiring a R8247https://www.hornby.com/uk-en/forum/dcc-points-wiring-/?p=1.TIP: As this is your very first post, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
