malc 64 Posted October 8, 2019 Share Posted October 8, 2019 ive just programed a new accessorry decoder using elite controller but by mistake I typed in 3 instead of 4 so now it changes points 9 to 12 which I've already got with decoder 3,can I reprogram the new decoder again to address 4 Link to comment Share on other sites More sharing options...
Chrissaf Posted October 8, 2019 Share Posted October 8, 2019 Yes, just go through the exact same process you used before, but this time use the address you want to use. This will just over-write the incorrect address..Just for information, writing 8 to CV8 will restore all R8247 settings to the factory default which is port DCC addresses 1 to 4 for ports 1 to 4. This 'factory reset' process is useful to know for when the R8247 gets corrupted due to a transient short circuit ocurring on the track. These Hornby R8247s are (unfortunately) sometimes affected this way by a track short on the DCC power feed. It is quite common. Link to comment Share on other sites More sharing options...
