L757 Posted October 26, 2019 Share Posted October 26, 2019 Hi. Returned to this hobby after 50 years. I've bought a pug loco from hattons £14.99 to have a go at installing a decoder. If I manage it I need to do this years club model and an 040 from the night mail set. I understand space is a concern and I've seen several small decoders advertised. Bearing in mind that these are all simple locos, is there a suggetion for a decoder that would be easy to install and suit all three. Thanks Link to comment Share on other sites More sharing options...
ColinB Posted October 26, 2019 Share Posted October 26, 2019 If space is tight I use 6 pin Decoders. Zimo do a really small one, although it is expensive. They also do a budjet one which I have used. In an old Replica Terrier I used the super small one as it was the only one that fitted in the available space. Link to comment Share on other sites More sharing options...
Howbi Posted October 26, 2019 Share Posted October 26, 2019 @L757.......if you are not likely to need lights on your locos then the Hornby X9659 4 pin decoder is ideal ........it does have a fitted socket which will need to be cut off and the four wires soldered in place.........there is plenty of space inside the Club shunter model.......the X9659 is out of stock with most retailers but a Google search did turn up some in stock at around £14.50........HB Link to comment Share on other sites More sharing options...
L757 Posted October 27, 2019 Author Share Posted October 27, 2019 Thanks for the suggestions. I can see the cheaper Hornby decoders as a pre order and the zimo looks good but is a bit more. Hattons do a cheap own brand and gaugemaster a cheap 4 pin. Any knowledge of either of these Link to comment Share on other sites More sharing options...
96RAF Posted October 27, 2019 Share Posted October 27, 2019 You can easily get an R8249 and a socket in an 0-4-0 /media/tinymce_upload/913ce62f5ce9c13745767c73e1f67062.JPG Link to comment Share on other sites More sharing options...
L757 Posted October 27, 2019 Author Share Posted October 27, 2019 Thanks for the photo Link to comment Share on other sites More sharing options...
96RAF Posted October 27, 2019 Share Posted October 27, 2019 Please note my wiring colours are non standard, I just used what I had in the box at the time. My blue and yellow should be orange and grey to accord with convention. Link to comment Share on other sites More sharing options...
Michael_A Posted October 29, 2019 Share Posted October 29, 2019 Thanks for the suggestions. I can see the cheaper Hornby decoders as a pre order and the zimo looks good but is a bit more. Hattons do a cheap own brand and gaugemaster a cheap 4 pin. Any knowledge of either of theseI have used about 20 of the Hattons decoders. Only comment is RailMaster won't always read them back, but nevertheless they do work. I also like the fact you can correct the speed with CV5 and CV6, which is great for a decoder in this price range. Link to comment Share on other sites More sharing options...
Michael_A Posted October 29, 2019 Share Posted October 29, 2019 I just ordered 10 Lais decoders at 9.50 each. Excuse the pun, but cheap as chips for the spec! Link to comment Share on other sites More sharing options...
cowside Posted November 10, 2019 Share Posted November 10, 2019 I've been using LAIS decoder chips for a while and they work fine. But if you want to connect a Stay Alive then you need to buy the KungFu version at about £12.50. I have used a KungFu with the LAIS Large Stay Alive on an old Lima Western class loco and it zips over every point, even the large radius Hornby curved points which are the most prone to sticking locos. Link to comment Share on other sites More sharing options...
