Steve K. Posted November 8, 2019 Share Posted November 8, 2019 Not sure if this is in right section (I can't see a Scalex Sport forum). Please move if necessary.So I've just set up/media/tinymce_upload/17d0fb0daf189c7377ffcfd07602db4b.jpg the WBR set up in my attic, but would like to add track to make more use of the table space I've created (178 x 170 cm- see photo). I can't go any longer-which would be the simplist option. I'm trying to work it out in Ultimate Racer track designer-but without much success.So, two questions:1. Anyone know a good way to extend this set (without increasing length)? (I could build upwards with bridges).2. If not, anyone got a different track design which would make better use of the space I've got? Obviously I'm aware this would involve buying more track. Link to comment Share on other sites More sharing options...
woodcote Posted November 12, 2019 Share Posted November 12, 2019 Hi Steve - welcome to the forum!I would keep working with Ultimate Racer, perhaps trying something like a 'B' shape - if that makes sense? Build a 'C' down one side and then a couple of loops to join up. That will give you more track length in the same space. Or start with a straight diagonally and then build either side with a bridge across to connect up. Link to comment Share on other sites More sharing options...
