Renning Posted June 22, 2011 Share Posted June 22, 2011 I got separately "Lord of the Isles" loco (amazing runner Triang R 354 running number 3046) and tender (Triang R 37, reads "Great Western") Lining color is the same, green is lightly different but acceptable. The real difference is a glossy loco and a mat tender. I would like to apply a varnish. Which one would be the best?Thanks in advance.Jean. Link to comment Share on other sites More sharing options...
Brightstar Posted June 22, 2011 Share Posted June 22, 2011 You could try a water=based lacquer used as a top coat on cars with metallic type paints. Link to comment Share on other sites More sharing options...
walkingthedog Posted June 22, 2011 Share Posted June 22, 2011 Oops!I use Humbrol varnish (always a new tin) and apply it with a wide flat good quality brush (new brush as well if possible). Unless you have access to an air-brush. Link to comment Share on other sites More sharing options...
Postman Prat Posted June 22, 2011 Share Posted June 22, 2011 I would use Matt but not fully stirred. With a new tin normally gives a nice semi-matt finish. However, varnish both of them - not so silly as it sounds, I knew someone who, when doing something similar to you, only applied the varnish to the loco!! (Or maybe the tender, Can't remember but you get my meaningwalkingthedog said:Oops!I use Humbrol varnish (always a new tin) and apply it with a wide flat good quality brush (new brush as well if possible). Unless you have access to an air-brush. Link to comment Share on other sites More sharing options...
The son of Triangman Posted June 28, 2011 Share Posted June 28, 2011 Why not just find a gloss tender to match the loco, they come up on the likes of eBay often enough. That way you aren't spoiling the models collectability Link to comment Share on other sites More sharing options...
