RMRED Posted December 7, 2019 Share Posted December 7, 2019 Railmaster Pro 1.70 r 2When I invoke the Quick Select screen, then press a button for a loco, the control screen scrolls up to that loco and the quick select screen disappears.I am expecting the quick select screen to remain visible, and show moving locos in its bottom r-h corner (. Do I need to do something to make this happen? Link to comment Share on other sites More sharing options...
Chrissaf Posted December 7, 2019 Share Posted December 7, 2019 As far as I know. The bottom right hand corner only displays locos that are actually moving on the layout and under some form of control. I believe that this is put there to remind you what (up to five locos) you have already selected whilst you choose another to control from the main panel. I also assume (I haven't tried this to confirm) that any of the possible 5 locos in the bottom right corner can be clicked as well to open the throttle for it..Once you have selected a loco to control - it is normal for the 'Quick Select' Window to close and I doubt that this is configurable, as there is no entry in the .INI file that I can find that might modify that behaviour. Link to comment Share on other sites More sharing options...
